| Funny lights?? https://mail.slantsix.org/forum/viewtopic.php?t=65404 |
| Author: | Rick Covalt [ Mon Oct 05, 2020 6:18 pm ] |
| Post subject: | Funny lights?? |
Friend is working on a 69 Dart and when he hits the brake pedal the parking lights come on up front. This sounds like some sort of a grounding issue to my pea brain. But where is a good place for him to start the search? |
| Author: | Joshie225 [ Mon Oct 05, 2020 7:16 pm ] |
| Post subject: | Re: Funny lights?? |
Turn signal switch is where these circuits come together. |
| Author: | DadTruck [ Mon Oct 05, 2020 7:35 pm ] |
When I put the 83 D150 back together after having it apart down to the frame rails, I had that exact same issue. Step on the brake pedal and the front parking lights would light. I have slept since then, but it was something in the rear wiring harness I had two plug in connectors swapped and plugged in wrong. |
| Author: | Badvert65 [ Mon Oct 05, 2020 7:39 pm ] |
It could also be a messed up rear tail lamp bulb (Brake/signal). I have seen the filaments short between the dim (park) and bright (signal) ans cause weird issues like that. |
| Author: | Rick Covalt [ Tue Oct 06, 2020 3:08 am ] |
Thanks guys, I'll pass those things along. |
| Author: | Badvert65 [ Tue Oct 06, 2020 7:02 am ] |
I also had a similar issue on a 66 Fury. When a bulb was put in the brake light socket, it would twist the socket contacts around (broken locator tab). The bulb contacts shorted across the two socket contacts. That was a difficult one to figure out. jus sayin.... |
