| k-frame swap https://mail.slantsix.org/forum/viewtopic.php?t=65776 |
| Author: | ceej [ Sun Feb 14, 2021 10:18 am ] |
| Post subject: | k-frame swap |
Looking at K-frame interchangeability between different generations of a-body. Specifically looking at using a 74 spool mount in a 63. Is it possible? CJ |
| Author: | Joshie225 [ Sun Feb 14, 2021 10:52 am ] |
| Post subject: | Re: k-frame swap |
Negative. It's too wide. A board member near Spokane once attempted to narrow a spool K-member for his early A-body, but threw in the towel AFAIK. |
| Author: | Reed [ Sun Feb 14, 2021 11:10 am ] |
Two main groups of interchangeability: 60-66, 67-76, if I remember correctly. |
| Author: | ceej [ Sun Feb 14, 2021 1:49 pm ] |
Okey Dokey. Thanks for the feedback Reed! CJ |
| Author: | Killer6 [ Sat May 15, 2021 7:54 am ] |
Quote: Okey Dokey.
I did a bunch of measuring a few years back, the basics are '67 and up chassis are about 2.5" wider, moving steering gear and t-bars, LCA/entire suspension out 1.25" each side. The engine mounting in relation to the frt suspension shifts the eng./trans back about 1.75"-1.875" compared to early-A's. These are the primary reason most headers fail to fit, but I heated, beated, & hammer welded/folded an older 6-1 MP/JR-Heddman to fit My '64 GT. It survived, but it ain't pretty, & that's with the manual box.Thanks for the feedback Reed! CJ If You want spools, & I don't blame You, best to get the mt./brackets & make Your own frame brackets/braces. |
