It is currently Tue Nov 18, 2025 6:43 am
PostPosted: Mon Apr 05, 2021 3:14 am
How can I stop the dip stick from rising from the oil filler tube?
When I drive my Valiant the dip stick rises about 1 inch out of the filler tube.
PostPosted: Mon Apr 05, 2021 3:58 am
Excessive blow by most likely time for a rebuild. I would run a compression test and a leak down test. You may also make sure your PCV system is working correctly and you have the correct style oil fill cap.
63 Plymouth Valiant Wagon
