Oil filler tube/dip stick
https://mail.slantsix.org/forum/viewtopic.php?t=65898
Author:  crickhollow [ Mon Apr 05, 2021 3:14 am ]
Post subject:  Oil filler tube/dip stick
How can I stop the dip stick from rising from the oil filler tube?
When I drive my Valiant the dip stick rises about 1 inch out of the filler tube.
Author:  bcschief [ Mon Apr 05, 2021 3:58 am ]
Post subject:  Re: Oil filler tube/dip stick
Excessive blow by most likely time for a rebuild. I would run a compression test and a leak down test. You may also make sure your PCV system is working correctly and you have the correct style oil fill cap.
