| A crank trigger to go with the cam sensor https://mail.slantsix.org/forum/viewtopic.php?t=65977 |
| Author: | MadScientistMatt [ Tue May 18, 2021 11:18 am ] |
| Post subject: | A crank trigger to go with the cam sensor |
The crank trigger is a prototype that was intended for a small block Chevy. I'm going to use a threaded Hall effect sensor here and a bit of square tubing welded to the timing cover. Some work in progress pictures: My welding skills aren't the greatest, but at least I don't have any more holes in the timing cover than I started with. |
| Author: | Dart270 [ Tue May 18, 2021 12:38 pm ] |
| Post subject: | Re: A crank trigger to go with the cam sensor |
Hi Matt, Looks very similar to what I did on mine. See pics at: https://flickr.com/photos/16910097@N06/ ... 2740650932 I used your cam sensor (fuel pump plate) idea and it is perfect! Thanks again. Lou |
| Author: | MadScientistMatt [ Wed May 19, 2021 10:31 am ] |
Looks like you were a bit more confident in your welding skills getting the gap right than I am! I went with a threaded Hall effect sensor. Everything ready now except paint and finishing the wiring. |
| Author: | emsvitil [ Wed May 19, 2021 7:18 pm ] |
Is that a 36-1 wheel? |
| Author: | MadScientistMatt [ Thu May 20, 2021 6:52 am ] |
Quote: Is that a 36-1 wheel?
Correct.
| Author: | Greg Ondayko [ Fri May 21, 2021 11:44 am ] |
Yes but it's a prototype SB chevy one that bolts nicely to the Romac for a slant 6 - would like matt/ Diyautotune to make some more of them... wink wink, nudge, nudge. Greg |
