| AC/HEATER rehook up https://mail.slantsix.org/forum/viewtopic.php?t=66038 |
| Author: | 86d100 [ Sun Jun 20, 2021 5:44 pm ] | ||
| Post subject: | Re: AC/HEATER rehook up | ||
(back of the ac/heater control)
| Author: | volaredon [ Mon Jun 21, 2021 5:29 am ] |
Looks just like what was on my 83. "Dealer add on" unit. Belt catalogs used to ask if you had factory air or dealer air, yours would be dealer air. |
| Author: | Charrlie_S [ Mon Jun 21, 2021 7:35 am ] |
Could allso be aftermarket add on air. I have done sevsral of those installs over the years. I should still have some install instructions someware. give me a couple of days, and if you still need info, send me a pm |
| Author: | 86d100 [ Mon Jun 21, 2021 5:05 pm ] |
Quote: Looks just like what was on my 83.
Ah that would make sense cause my factory manual didnt even have a wire diagram for it lol. My duster was a VA car originally too and it had "dealer" add on air conditioning.
| Author: | 86d100 [ Mon Jun 21, 2021 5:06 pm ] |
Quote: Could allso be aftermarket add on air. I have done sevsral of those installs over the years.
If you do that would be great
| Author: | Charrlie_S [ Mon Jun 21, 2021 5:52 pm ] |
Quote: Quote: Could allso be aftermarket add on air. I have done sevsral of those installs over the years.
If you do that would be greatI should still have some install instructions someware. give me a couple of days, and if you still need info, send me a pm PS: That green box is an electronic thermostat |
| Author: | 86d100 [ Wed Jun 23, 2021 1:35 pm ] | ||
Quote: Quote: Quote: Could allso be aftermarket add on air. I have done sevsral of those installs over the years.
| Author: | Charrlie_S [ Wed Jun 23, 2021 2:32 pm ] |
Yep, that is an aftermarket A/C kit. I know of them, but don't think I have any literature for their units. I'll take a look. Actually most of them used very similar wiring. On that blue box (just going by failing memory) two wires go to a thermister in the evaporator. two wires went to a variable resistor connected to the temp control (either on the control head, or the lever on the evap case). One wire for +12volt, one wire for ground, and one wire to the compressor clutch. |
| Author: | 86d100 [ Fri Jun 25, 2021 2:02 pm ] |
Quote: Yep, that is an aftermarket A/C kit. I know of them, but don't think I have any literature for their units. I'll take a look. Actually most of them used very similar wiring.
Well I'll be dipped didnt even know they did that. I do see the 2 wires coming out from the evap core (no connector for it) and the resistor (looks like a relay) up on the fire wall. I'll have to play around with it. Thanks for the info
