| Gas pedal twisty rods? 60-64 https://mail.slantsix.org/forum/viewtopic.php?t=66159 |
| Author: | Greg Ondayko [ Tue Aug 31, 2021 10:18 am ] |
| Post subject: | Gas pedal twisty rods? 60-64 |
Are the throttle rods the same for a 225 and 170? I now have one of each and was curious about the interchangeability. Did '65 and '66 also use the throttle rod or did it get changed to a cable type assembly? Thanks, Greg |
| Author: | Rick Covalt [ Tue Aug 31, 2021 2:26 pm ] |
| Post subject: | Re: Gas pedal twisty rods? 60-64 |
65 Slant 6 had the rod, V8 had cables. I think 66 changed to all cables but I am not sure. |
| Author: | SlantSixDan [ Wed Sep 01, 2021 11:13 am ] |
The only pre-'67 LHD Slant-6 A-bodies that had cable-type throttle were those with factory air. All others had the rotating-rod setup, in which some parts are different for 170 vs. 225. |
| Author: | Greg Ondayko [ Wed Sep 01, 2021 3:09 pm ] |
Cool. Thanks for the info. Sorry for so many questions, no one around gere knows or cares about anything for these cars. I appreciate the resources! Greg |
| Author: | bcschief [ Wed Sep 01, 2021 6:53 pm ] |
Quote: Are the throttle rods the same for a 225 and 170?
I now have one of each and was curious about the interchangeability. Did '65 and '66 also use the throttle rod or did it get changed to a cable type assembly? Thanks, Greg No they are different lengths 170 is shorter than 225 because of the deck height difference of the block. |
