All out N/A engine timing curve
https://mail.slantsix.org/forum/viewtopic.php?t=66172
Author:  Greg Ondayko [ Wed Sep 08, 2021 6:59 pm ]
Post subject:  All out N/A engine timing curve
I have been thinking about possible reasons why my Ruster is somewhat slow off the line.
Since I trashed the distributor back in 2014 or so I have been running fixed timing as I do not have a vacuum feed to the megasquirt... yet
So I was thinking of Drilling the carb and adding a full vacuum feed to the data input of the ms3 so it can get map data.
If I do this I can then run a map based on load and rpm.
Do you think this will be advantageous... getting a better 60' time?
Author:  DadTruck [ Wed Sep 08, 2021 7:51 pm ]
Post subject:  Re: All out N/A engine timing curve
So you have the MS3 only controlling ignition? And the fuel side is a carb?
In Tuner Studio do you have an ignition option to ‘use table’ under the Ignition Settings tab? You should be able to have a variable user defied ignition curve regardless of the fuel setting. My MS3 Pro does not use Map or kPa or a vacuum signal to adjust the timing curve. kPa is an input for constructing the VE and AF tables. But those do not link to the ignition timing table.
Author:  slantzilla [ Wed Sep 08, 2021 9:03 pm ]
What was your 60' if I may ask Greg?
Author:  slantzilla [ Wed Sep 08, 2021 9:08 pm ]
Leaving off a brake the curve should be irrelevant. Timing should be all in well before launch rpm.
I know my junk was dead to the 60 when I had 38° total in it. 32° really woke it up.
Have you tried leaving off the footbrake to take the 2 step out of the equation? Sometimes it can get so fat on the 2 step and it takes a little while go clear.
Author:  Dart270 [ Thu Sep 09, 2021 5:39 am ]
If you control timing with the MAP sensor, you should try it. However, I agree with a high stall converter this really shouldn't matter much at all. Manifold should have a vacuum port/plug on it. I like Dennis' idea. My bet it is the fuel mixture, not ignition.
Author:  Greg Ondayko [ Thu Sep 09, 2021 6:53 am ]
Well Right now the car has MS3 for timing only.
Fuel is run by the carb.
O2 Sensor wires crapped out on me while doing 12 hrs of trailering so I cannot get fuel / O2 data but I would also surmise that with WOT Carb on spark cut it's super rich on the brake/2 step.
I also can do the Transbrake and shut the 2 step off.
I have some experimenting to do, and can definitely go back to the footbrake and try it out.
if I had Electonic injection I could tell MS3 to Cut fuel and spark, but not yet.. it's on the wishlist. Too many cool projects /Ideas and not enough time.
Hey Lou.. need some R&D time on the ITB's?!?!? :D :D
@ Slantzilla - the 60' times are slow like in the 1.66 area - I would like to be ~0.2 Sec's Faster than that.
Author:  slantzilla [ Thu Sep 09, 2021 4:40 pm ]
I'm not sure you have enough steam for a 1.46, but you should get in the mid .50s.
