It is currently Tue Nov 18, 2025 1:02 pm
PostPosted: Thu Sep 09, 2021 9:06 pm
Car Model: 1966 2D Dart
I have early 170 engine and late model 904. There is a fitment problem with converter hub. As the converter is custom piece (small diameter, high stall) I like to keep as is. So I have onlys choice to ask machinist to made my small register 170 crank to perfect fit.
I have found a machinist to do it.
I am pretty sure that has done before several times. I have calculated there is enough material to do it. Just to the inner hole to 1.81” and add an outer ring for flex plate centering (1.96”/2.16”)
Please advice me to topics where this is discussed before.
(I am overseas. Slant parts are not laying all around. Was a job to catch 170 bottom end which is not at biggest overbore and ”end”. Now I have a good project engine).
PostPosted: Fri Sep 10, 2021 3:23 pm
Machine the counter-bore out to the larger size and use the early flex plate (small bore size) and everything works fine.
PostPosted: Fri Sep 10, 2021 4:30 pm
Awesome mod Doc! Thanks for Sharing.
PostPosted: Sat Sep 11, 2021 3:03 am
Thanks!
PostPosted: Sat Sep 18, 2021 8:55 pm
One more question. What is the needed size for re-machined counterbore? Is it 1.81" (46,0mm) or 1.815" (46,1mm)?
PostPosted: Mon Sep 20, 2021 5:03 pm
1 13/16 inches = 1.8125
Best to measure the hub on the torque converter and add .002 for clearance.
