It is currently Tue Nov 18, 2025 3:29 am
PostPosted: Thu May 19, 2022 10:59 am
Car Model: 1968 barracuda slant six 4speed super charged
T&D roller rockers.. anybody who has them remember their push rod length?
I need to order some. Thanks
PostPosted: Thu May 19, 2022 3:13 pm
I just put a set of roller rockers on the 68 Barracuda, your best bet is to buy or make a push rod checking tool to be sure the push rod-adjuster length is right for your engine.
The pushrod length can be different depending upon a stock vs a re ground cam being installed. If the block and or head has been cut. The length of the pushrod from someone else’s engine may not be the best choice for your engine.
If you are interested in getting the rocker arm geometry absolutely right with your roller rocker set up.
Google B3 Racing Engines, that company specializes in fixing issues with Mopar shaft mounted rocker arms. I put one of their kits in and it made a remarkable improvement in the rocker arm to valve tip contact patch.
