Testing voltage regulators
https://mail.slantsix.org/forum/viewtopic.php?t=66448
Page 1 of 1
Author:  tattoosteve99 [ Mon Feb 07, 2022 1:52 pm ]
Post subject:  Testing voltage regulators
Besides putting them on and see if it works is there a bench test? I have several I want to test since I have found my problem. Any ideas? FSM is no help here
Author:  Chuck [ Sat Feb 25, 2023 10:50 am ]
Post subject:  Re: Testing voltage regulators
I think that installing them is the only sure way.
Author:  MadScientistMatt [ Sat Mar 04, 2023 3:12 pm ]
You might be able to use an adjustable voltage power supply and a test light. Wire the test light like it's the field coil, see what voltage makes it turn off and on. The function of the regulator is to switch the field coil on below a set voltage, but it may also have some sort of intentional pulse function or other complications.
Author:  SlantSixDan [ Sat Mar 04, 2023 3:55 pm ]
You don't mention whether you're trying to test '69-down or '70-up regulators. '70-up regulator test info here and here.
Author:  volaredon [ Sat Mar 04, 2023 4:12 pm ]
Years ago when I worked the parts counter we had an alternator test machine that also had a VR test option, had plug ins for the common Mopar and Ford regulators and alligator clips for any of the point type ones with a different position for each on the tester
Author:  tattoosteve99 [ Wed Mar 15, 2023 9:32 pm ]
That YouTube link was one I already watched as well. Thanks for the input Dan. I always appreciate you helping this old man out.
