Slant Six Double Barrel Carb?
https://mail.slantsix.org/forum/viewtopic.php?t=66538
Author:  SpriceyStuff [ Wed Apr 06, 2022 9:29 pm ]
Post subject:  Slant Six Double Barrel Carb?
Hey guys! I’m trying to do a mildish performance slant six build, as when I swap my 360 into my dart sport, i don’t want the slant to go to waste so I would like build my slant and find another small car to drop it into and see how much power I can squeeze out of it. I have a 2 barrel Stromberg off of a 318. I see that someone else has used one before, but would that be ideal or should I go with a carter? Also, when I make the switch from single to double barrel carb, how do I remedy the fact that the kickdown linkages are on different sides between the two carb types? Is there another linkage I need? Any advice or information would be greatly appreciated.
Author:  DadTruck [ Sun Apr 10, 2022 6:39 pm ]
Post subject:  Re: Slant Six Double Barrel Carb?
Super Sixing a slant will wake them up, but just going from a one bbl to a two bbl carb is realistically only about 10 or so hp. So if you are looking for a dramatic improvement, it’s more than the carb.
I am not familiar with the Stromberg carb, but the Holley 2280 and the Carter BBD carbs have the throttle and kick down attaching points on the same side as the Holley 1920 and BBS carbs. I do think that the divorced chokes hook up a bit different between the 2 and 1 bbl carbs.
Author:  volaredon [ Mon Apr 11, 2022 3:58 am ]
Yup. I found a place on eBay last year that had the different pieces needed for a/6 vs using the same BBD on a 318 for the choke to hook up right.
There is a posting in the article section telling the difference between a true /6 BBD and a 318 one and I remember a posting elsewhere on the site where someone added a tab to the original 318 linkage to let a /6 choke element to connect as they are supposed to. It wasn't all that much work to do
