35, 50, 75 wet Nitrous kit for Slant 6
https://mail.slantsix.org/forum/viewtopic.php?t=66542
Author:  Valleyant [ Tue Apr 12, 2022 11:12 pm ]
Post subject:  35, 50, 75 wet Nitrous kit for Slant 6
I have a 1974 Plymouth Duster with a 198 and auto combination. I would like to try one of these kits for the drag strip. If I do, where is the best place to install the fuel/nitrous nozzle?......can I use an EGR block off plate and weld a bung on there for this? Thanks
I want to add that this car is all stock with the 1945 Holley 1 barrel carb and intake and stock exhaust manifold.
Author:  GTS225 [ Wed Apr 13, 2022 5:40 am ]
Post subject:  Re: 35, 50, 75 wet Nitrous kit for Slant 6
Spraying in at the bottom of the plenum? I think not. Seems to me the airflow wouldn't mix it very well with the charge from the carb. That kind of thing leads to blown/burned engines.
I suggest the proven method of a spray plate just under the throttle body of the carb.
Roger
Author:  slantzilla [ Wed Apr 13, 2022 7:45 am ]
Doug used to spray on a 1bbl intake. IIRC, it was in the side of the plenum. Maybe he'll see this and chime in.
Author:  Valleyant [ Thu Apr 14, 2022 6:10 pm ]
I did see a picture online of a red one-barrel intake, looked to be aluminum, that had the Fuel and Nitrous solenoids mounted on it with the drilled/tapped threads for the nozzles. Gives me an idea for sure. Thanks
