It is currently Tue Nov 18, 2025 3:03 am
 Post subject: Tow Hook
PostPosted: Wed Apr 06, 2022 9:31 am
Since I have the front grill work and bumper off the 68 Barracuda, I think I want to add a front tow hook.
The front bumper is fiberglass with lightweight aluminum bumper mounts, and the front spoiler would really limit access to the k frame.
I am thinking of a simple 3/8 inch thick steel L bracket that would bolt to the passenger side sub frame where the bumper mount is, with the L forward and below the bumper with an eye on it for attaching a pull cable hook. Sound reasonable?
Any other ideas?
 Post subject: Re: Tow Hook
PostPosted: Wed Apr 06, 2022 11:00 am
I used a G Force one:
Front view shows additional tow strap added.
They can be found Here
I bolted directly to the front bumper mount.
What you propose probably works if you have the fiberglass bumper installed in place of the OE bumper.
PostPosted: Thu Apr 14, 2022 4:54 pm
The tow hook is made and mounted. Weighed in at 3.8 lbs
I would have liked to use a strap like Greg did, but I needed it to get below the front bumper so in use the pull cable would not put pressure on the fiberglass bumper.
