Pressure plate bolts
https://mail.slantsix.org/forum/viewtopic.php?t=66549
Page 1 of 1
Author:  J S Goldman [ Mon Apr 18, 2022 6:36 am ]
Post subject:  Pressure plate bolts
Does anyone know the tork spek for the pressure plate bolts on a 66 /6?
Author:  Greg Ondayko [ Tue Apr 19, 2022 4:51 am ]
Post subject:  Re: Pressure plate bolts
I am sure I have that Information somewhere in a service Manual...If I can remember when I am at home I will look it up and post it.
If you are using the proper bolts and lock washers It's not super tight - I know I have Broken those off before when I got "torque happy"
ARP sells a nice replacement set of those as well.
Author:  Charrlie_S [ Tue Apr 19, 2022 5:15 am ]
From 66 factory service manual
Flywheel 55 lb/ft
5/16 clutch cover bolts 15 lb/ft
3/8 clutch cover bolts 30 lb/ft
Author:  Greg Ondayko [ Tue Apr 19, 2022 6:30 am ]
Woo Hoo!
Thanks Charrlie!
See you at the paddock.
Author:  Dart270 [ Tue Apr 19, 2022 11:15 am ]
Wow 15 ft-lbs. That is nothing. Sounds like vibration backout city. I usually do it by hand/feel to 30-40 for 5/16" PP bolts, and at least 80 ft-lbs on the flywheel to crank. None broken so far. I have used long PP bolts and nuts on the backside to lock them also.
Author:  Greg Ondayko [ Tue Apr 19, 2022 6:44 pm ]
I know I have broken stock ones So that 15# is probably correct. Prolly Not a Worry if you go a Few Ft/lb More with the ARP's and Red Loctite.
No Reason I would hesitate to use loctite Red on the stock Bolts as well.
Lou, I see your point on a more performance oriented build. Service manual specs were for smooth running one barrels screaming for air with teeny tiny valves at 3600 RPM.
