| Alternator Behaving Badly?!? Stator Coil issues. https://mail.slantsix.org/forum/viewtopic.php?t=66753 |
| Author: | Greg Ondayko [ Fri Sep 02, 2022 5:38 pm ] |
| Post subject: | Alternator Behaving Badly?!? Stator Coil issues. |
I have an alternator - non OE Chrysler Type - Nippendenso Small style - 30-40 Amps - Not exactly sure as there is no part # on it. It may be one of those Kubota Tractor ones. - Internally regulated. Anyway It has 4 Leads to the from the Diode terminals / block to the stator coils.. If I test for continuity between the Stator coil leads (any of the four) and the Stacked Stator Frame (steel laminations) I should get an open circuit / no resistance correct? Thank you, Greg |
