How to remove car battery
https://mail.slantsix.org/forum/viewtopic.php?t=66786
Page 1 of 1
Author:  crickhollow [ Wed Sep 28, 2022 10:28 pm ]
Post subject:  How to remove car battery
Which battery cable should I disconnect first - positive or negative cable, and why?
I have a 61 Valiant.
Thanks
Author:  volaredon [ Thu Sep 29, 2022 3:48 am ]
Post subject:  Re: How to remove car battery
Either will work but I was told years ago negative first. And reconnected last
Author:  Badvert65 [ Thu Sep 29, 2022 4:56 am ]
Disconnect the negative lead first. If the wrench accidently hits something (fender, radiator yoke, bracket, etc) it won't matter because everything is essentially ground. Then, with the negative post clear, it won't matter if the wrench hits something (fender, radiator yoke, bracket, etc) as you remove the positive cable from the battery.
It is just a basic safety precaution to reduce the chance of shorting the battery during an 'oops' moment.
Electrically, it doesn't matter which cable is removed first.
jus sayin....
Author:  Dart270 [ Thu Sep 29, 2022 6:16 am ]
Matt said it perfectly.
Author:  crickhollow [ Fri Sep 30, 2022 3:20 am ]
Thanks Matt.
