| Help with HEI module https://mail.slantsix.org/forum/viewtopic.php?t=67027 |
| Author: | Slantsix83 [ Sat Jan 14, 2023 4:35 pm ] |
| Post subject: | Help with HEI module |
I have a 2000s cheby hei module with the 4 pin connectors oem they have 4 wires coming out, also im going to use a 80s ford coil and ive adapated the distributor for electronic ignition. Question will I also need a relay an if so how will i hook it up with a simple set up? Gm part number GM 089 5A21 |
| Author: | SlantSixDan [ Sat Jan 14, 2023 5:21 pm ] |
| Post subject: | Re: Help with HEI module |
Read the HEI upgrade article for particulars and details. |
| Author: | Slantsix83 [ Sun Jan 15, 2023 8:31 am ] |
Quote: Read the HEI upgrade article for particulars and details.
I did but i didnt seem to find about the 4 pin connector
| Author: | SlantSixDan [ Sun Jan 15, 2023 10:06 am ] |
The entire article is about the 4-pin module… ¯\_(ツ)_/¯ |
| Author: | Slantsix83 [ Wed Jan 18, 2023 4:49 am ] |
Quote: The entire article is about the 4-pin module… ¯\_(ツ)_/¯
Would you recommend adding a relay to the mix?
| Author: | Rick Covalt [ Wed Jan 18, 2023 9:11 am ] |
Others will probably recommend one but I have 3 vehicles running without them and all have 13+ volts at the module. Been running them for 3-8 years |
| Author: | hank2 [ Tue Feb 14, 2023 11:10 pm ] |
I used a Delphi DS10071 module about 4 or 5 years ago. I have a couple of supposedly real AC Delco 4 pin modules somewhere but haven't needed them yet. I intended to install a relay but have never gotten around to it. I used a NOS GM coil with factory mount intended for a late 70's Chevette engine mount. I mounted the bracket on the fender in my truck. Got a couple of assemblies on ebay. I've forgotten the GM part no. for coil and bracket, but the coil is equivalent to the SM DR35. |
