| Carb Linkage bushing https://mail.slantsix.org/forum/viewtopic.php?t=67099 |
| Author: | SlantSixDan [ Tue Feb 21, 2023 3:05 pm ] |
| Post subject: | Re: Carb Linkage bushing |
You grab the body of the bushing with a big pair of pliers, and pull it so the flanged head pops inward through its holeā¦done. Easy-peay, lemon-squeezy. The bigger question is what you are going to do with this U-shaped piece of metal with the bushing in it. It's not meant to be a separate item like this; it's part of the carb's throttle shaft. Is there some spot-welding in your future? Oh, and the bushing is available as a new part. |
| Author: | valleyguy [ Wed Feb 22, 2023 4:27 am ] |
yes I had intended to try to spot weld this bracket to another carb (which had a different linkage type, but well, that didn't work out..lol, the linkage was just too different to make it workl. |
