| 1962 Valiant Station Wagon https://mail.slantsix.org/forum/viewtopic.php?t=67103 |
Page 1 of 14 |
| Author: | drgonzo [ Thu Feb 23, 2023 9:24 am ] |
| Post subject: | Re: 1962 Valiant Station Wagon |
That's lookin' good Greg. |
| Author: | Greg Ondayko [ Thu Feb 23, 2023 10:31 am ] |
Thanks, I should get to the distributor tonite, it needs cleaned and I will rebuild it too. The pertronix Ignitor II arrived in the mail today. New Dist. Gear, Clean and respring it as well as reset the timing. I have verified that the vacuum advance can works and it does... But I have yet to check the timing but it's going to be reset anyway. Greg |
| Author: | Dart270 [ Thu Feb 23, 2023 11:25 am ] |
Great vehicle and getting better! Hah, I guess I am lucky I got a fully street/strip 62 Valiant from Mr. Seymour Pederson. No heater box, so much easier VC r'n'r on mine... Lou |
| Author: | SlantSixDan [ Fri Feb 24, 2023 6:52 pm ] |
Quote: Had to remove most of the passenger side engine components and engine bay components on the same side to shimmy the Valve cover Make the heater hoses just a little longer than absolutely necessary, just long enuf that you can flop them over the valve cover toward the manifolds when removing the valve cover. Remove the RH horn and pull the spark plug wires off the plugs. Unbolt the valve cover, lift it and rotate it counterclockwise (as viewed from the front; you're turning it down over the spark plug side of the head). When you get the angle just right, you can pluck the cover off out from under the heater box.Or just install a 170 engine, then it's easy! Quote: remanufactured alternator Careful; most of these are much higher output than the original 30- to 35-amp rating because some ignorant dillweed decided to consolidate everything up to 50A to a 50A unit. The wiring on a '62 is marginal even when new, and there's almost no circuit protection. See here; here; here, and here.Engine spiff-up is lookin' terrific! DS |
| Author: | Charrlie_S [ Sat Feb 25, 2023 3:41 am ] |
Quote: Quote: remanufactured alternator Careful; most of these are much higher output than the original 30- to 35-amp rating because some ignorant dillweed decided to consolidate everything up to 50A to a 50A unit. The wiring on a '62 is marginal even when new, and there's almost no circuit protection. See here; here; here, and here.Engine spiff-up is lookin' terrific! DS |
| Author: | Greg Ondayko [ Tue Feb 28, 2023 6:41 pm ] |
Getting Caught up on some of my Uncle Dan Documentation. Will have to go and upgrade to the Additional Fuses method of alternative wiring out of the alternator. For now, I just have one additional 8 Gauge wire Running from the Alternator to the Stater Relay Battery +. I put a clamp on ammeter on the 2 Wires coming from that remanufactured alternator and Ran the Fan, Dome Lights Radio / Hi beams etc... It would spike the output up to about 70 Amps at times, while Idle was at 30-40 Amps. Thanks Charrlie and Dan. That leads me to my next question.. How do the rebuilders change an original 30 Amp Alternator into say a 60 Amp unit? Is the field or stator or both changed to a part with more windings from the alternator rebuild parts supply house? Cheers, Greg |
| Author: | SlantSixDan [ Tue Feb 28, 2023 7:36 pm ] |
Quote: How do the rebuilders change an original 30 Amp Alternator into say a 60 Amp unit? Max output depends on the winding characteristics of the stator and rotor. Cheap and nasty hi-amp upgrades just throw a 'bigger' stator at it…which, yes, increases the max output, but torpedoes the alternator's low-RPM output. Cheap and nasty 'remanufacturing' processes involve just throwing alternators together with whatever stator and rotor comes to hand. Results are random and usually at least one kind of bad. The stator and rotor really need to be appropriately matched to each other. You might want to save yourself a whole lot of aggravation and just get a new Chrysler alternator from Old Car Parts Northwest. Most (maybe all) the ones they have on shelf are '70-up dual-field types, but those are easy to use on a '69-down car; just ground one of the two field terminals and then hook up the alternator as normal.
| Author: | Charrlie_S [ Thu Mar 16, 2023 8:16 am ] |
Quote: Quote: How do the rebuilders change an original 30 Amp Alternator into say a 60 Amp unit? Max output depends on the winding characteristics of the stator and rotor. Cheap and nasty hi-amp upgrades just throw a 'bigger' stator at it…which, yes, increases the max output, but torpedoes the alternator's low-RPM output. Cheap and nasty 'remanufacturing' processes involve just throwing alternators together with whatever stator and rotor comes to hand. Results are random and usually at least one kind of bad. The stator and rotor really need to be appropriately matched to each other. You might want to save yourself a whole lot of aggravation and just get a new Chrysler alternator from Old Car Parts Northwest. Most (maybe all) the ones they have on shelf are '70-up dual-field types, but those are easy to use on a '69-down car; just ground one of the two field terminals and then hook up the alternator as normal.Had a couple of used rebuilt alternators tested. One round back, and one square back. The round back tested at 82 amps max, and the square back tested at 87 amps max. |
| Author: | Greg Ondayko [ Thu Mar 30, 2023 5:41 am ] |
Quote: Quote: Quote: How do the rebuilders change an original 30 Amp Alternator into say a 60 Amp unit? Max output depends on the winding characteristics of the stator and rotor. Cheap and nasty hi-amp upgrades just throw a 'bigger' stator at it…which, yes, increases the max output, but torpedoes the alternator's low-RPM output. Cheap and nasty 'remanufacturing' processes involve just throwing alternators together with whatever stator and rotor comes to hand. Results are random and usually at least one kind of bad. The stator and rotor really need to be appropriately matched to each other. You might want to save yourself a whole lot of aggravation and just get a new Chrysler alternator from Old Car Parts Northwest. Most (maybe all) the ones they have on shelf are '70-up dual-field types, but those are easy to use on a '69-down car; just ground one of the two field terminals and then hook up the alternator as normal.Had a couple of used rebuilt alternators tested. One round back, and one square back. The round back tested at 82 amps max, and the square back tested at 87 amps max. Good data , thanks for sharing. Greg |
| Author: | drgonzo [ Thu Mar 30, 2023 9:09 am ] |
It's a sweet ride! Lookin' good Greg. |
| Author: | Greg Ondayko [ Thu Mar 30, 2023 10:28 am ] |
Quote: It's a sweet ride! Lookin' good Greg.
Thanks for the kind words Brad! |
| Author: | Greg Ondayko [ Fri Oct 06, 2023 10:32 am ] |
| Post subject: | 10/6/23 |
10/6/23: Labor Day weekend in the 62 Valiant wagon: Loaded up to go to a local community day festival. Ava was selling her jewelry. ![]() ![]() ![]() ![]() Ava made the local paper too: https://triblive.com/local/westmoreland ... -all-ages/ Then Off to a car cruise and dinner later that night. Sunday we went to the local amusement park - we had the only ' 62 valiant there. Last nite, we drove to Buttermilk Falls for a nice October drive into the mountains... I could not resist taking some pictures. ![]() If you look carefully there is a silly-faced kid in there ![]() ![]() ![]() ![]() It is also a rare time when both '62's share the same garage bay at home:-) ![]() ![]() Till next time. |
| Page 1 of 14 | All times are UTC-08:00 |
