It is currently Tue Nov 18, 2025 5:13 am
PostPosted: Thu Mar 02, 2023 10:59 am
Online
I do not have access to a proper "Connecting rod heater";
can I use a Mapp / Propane Torch to heat the small end to drop the pin through?
I can also freeze the Piston pins to hopefully make them a few 0.0001"ths smaller.
Thank you sages,
PostPosted: Thu Mar 02, 2023 11:06 am
Car Model: 64 Valiant
Your torch setup will be fine and heat the rods to expand them effortlessly. No need to freeze the pins. You'll just need to make a pin stop so they will be centered once you install them....
PostPosted: Thu Mar 02, 2023 11:53 am
Online
Sounds good thanks,
I just do not want to somehow damage the rods from overheating.
Users browsing this forum: No registered users and 35 guests
