| Fitting Piston Pins onto Stock Rods https://mail.slantsix.org/forum/viewtopic.php?t=67121 |
| Author: | Greg Ondayko [ Thu Mar 02, 2023 10:59 am ] |
| Post subject: | Fitting Piston Pins onto Stock Rods |
I do not have access to a proper "Connecting rod heater"; can I use a Mapp / Propane Torch to heat the small end to drop the pin through? I can also freeze the Piston pins to hopefully make them a few 0.0001"ths smaller. Thank you sages, Greg |
| Author: | CNC-Dude [ Thu Mar 02, 2023 11:06 am ] |
| Post subject: | Re: Fitting Piston Pins onto Stock Rods |
Your torch setup will be fine and heat the rods to expand them effortlessly. No need to freeze the pins. You'll just need to make a pin stop so they will be centered once you install them.... |
| Author: | Greg Ondayko [ Thu Mar 02, 2023 11:53 am ] |
Sounds good thanks, I just do not want to somehow damage the rods from overheating. |
