Difference Between Wix 51515 & 51806?
https://mail.slantsix.org/forum/viewtopic.php?t=67127
Page 1 of 1
Author:  Greg Ondayko [ Wed Mar 08, 2023 2:32 pm ]
Post subject:  Difference Between Wix 51515 & 51806?
What is the advantage of one over the other?
I have used 51515's for a while now on many of my MoPar stuff. Is 51806 better somehow?
Thank you sages!
Author:  SlantSixDan [ Wed Mar 08, 2023 4:18 pm ]
Post subject:  Re: Difference Between Wix 51515 & 51806?
51806 contains a built-in standpipe; 51515 does not. Other than that they are substantially alike.
Author:  Greg Ondayko [ Wed Mar 08, 2023 5:42 pm ]
Cool thanks Uncle Dan.
Is the built in standpipe of 51806 somehow better flowing than the stock steel stand pipe and small check valve on the filter base / oil pump?
Author:  Killer6 [ Wed Mar 08, 2023 8:30 pm ]
I will add that according to the Wix catalog, the oil bypass is set at 22psi in the 806, vs ~9psi for the 515.
Author:  SlantSixDan [ Thu Mar 09, 2023 9:49 am ]
No data; I'd just be guessing.
Author:  Greg Ondayko [ Thu Mar 09, 2023 10:23 am ]
Thank you.
I suppose the 51086 is worth a try for me as I just got rid of a standpipe for my latest build and I have a bunch of 51515's to compare it with.
Author:  SlantSixDan [ Fri Mar 10, 2023 11:45 am ]
With the 51806 bringing its own standpipe, you could optimise the filter adapter—bore it out and round its inlet and outlet edges to minimise flow restriction.
Author:  Greg Ondayko [ Fri Mar 10, 2023 1:34 pm ]
I will likely try that thanks again!
Author:  drgonzo [ Fri Mar 10, 2023 3:59 pm ]
I noticed I have a 51515X, says it's for full synthetic oil.
Author:  DadTruck [ Sat Mar 11, 2023 7:38 am ]
Any automotive engine oil filter will work with any automotive engine oil.
Better filters have the ability to strain out smaller particles and at the same time have better flow rates and more robust construction. But stating that a specific type of oil filter is required for synthetic engine oil is a stretch.
Author:  Rick Covalt [ Sat Mar 11, 2023 10:12 am ]
I would guess that is some kind of marketing gimmick? I have been using both of these filters for years with non synthetic oils.
