Timing Issue
https://mail.slantsix.org/forum/viewtopic.php?t=67219
Author:  valleyguy [ Mon May 01, 2023 12:47 pm ]
Post subject:  Timing Issue
Tying to adjust the timing on my 170 slant six; pretty straight forward, but.. the distributor hold down bolt (slot) only allows for limited movement., I need to turn my distributor a little more clockwise., but I can't. Anyone else have this problem??
Author:  Badvert65 [ Mon May 01, 2023 1:15 pm ]
Post subject:  Re: Timing Issue
The distributor plates like yours actually have two slots. One you can readily see and the other is reached from the underside of the distributor.
Author:  Greg Ondayko [ Mon May 01, 2023 2:54 pm ]
You need to get the special wrench or take the dist. out to access the 2nd adjustment screw.
I have also set the dist. in one tooth off to give me more adjustment on the top side slot sometimes too!
