| A903 3 speed manual transmission - WANTED https://mail.slantsix.org/forum/viewtopic.php?t=67235 |
| Author: | Rudized [ Wed May 10, 2023 2:16 pm ] |
| Post subject: | A903 3 speed manual transmission - WANTED |
Hoping for some help and leads. Looking for a donor or rebuilt or re-manufactured 3 speed manual transmission for a slant 6, 1960's Dodge. I believe it is the A903. Located in Ontario, Canada. Thanks! |
| Author: | Charrlie_S [ Wed May 10, 2023 5:04 pm ] |
| Post subject: | Re: A903 3 speed manual transmission - WANTED |
Is there a tin cover on the top of the trans, or is the side cover bolted on? Does the trans have a flange on the back that has the driveshaft bolted to it, or does the drive shaft yoke slide into the trans? |
| Author: | Kurt [ Mon Jan 15, 2024 3:05 am ] |
I have a really tight colum shift out of a 66 valiant slip yoke rear, this is a nonsyncro first gear trani. Does not need anything but a new tail shaft seal just for safe. Gust put it in and quiter than I have had in 20 years. The only reason I pulled it was to go to a 3speed overdrive. I am in Orlando Fl kdb1219@yahoo.com |
