It is currently Mon Nov 17, 2025 9:31 am
PostPosted: Mon Jun 05, 2023 11:07 am
Car Model: 1985 D 150
I want to use electrolysis on my block and head. Are there any aluminum parts or aluminum plugs to be worried about or is electrolysis generally safe on a slant 6?
PostPosted: Tue Jun 06, 2023 7:40 am
Not something I've seen asked before pertaining to an engine.
I see it asked in the tractor forums, usually in rust removal from fenders and such. But you should be safe in doing so if you so desired... On any "plugs" all I can think of would be something like freeze plugs which are usually steel but could be brass/ in any case especially since I'm guessing you're wanting to do this to clean internal water passages and such, I'd want to pop those out anyway so that the solution could get into every nook and cranny.
You must have a big tank to be able to dunk a head and block....
PostPosted: Tue Jun 06, 2023 2:47 pm
Car Model: '23 T-bucket
Ummm.....electrolysis is a line-of-sight procedure. If you want to get into the little passages, you'd have to run wires into/through them, with the wires hooked into your anode grid. Otherwise, the only surface to get cleaned would be the exterior.
Roger
PostPosted: Tue Jun 06, 2023 8:06 pm
Roger
Interesting. Didn't know that. I thought as long as the tub, drum, etc was big enough to completely submerge parts in the solution within, that it would clean everything within.
PostPosted: Tue Jun 06, 2023 8:31 pm
Nope. Just like chrome plating, but in reverse. There has to be an unobstructed path between cathode and anode. Chrome plating is just chromium dissolved into a solution, and the act of passing current through it carries the metals with it to adhere to the base metal.
Electrolosis is doing just the opposite.....removing contaminants from the surface of the base metal, and plating the anode with it. Yes....the anode is sacrificial in the process.
(This is an over-simplified explanation, but the basics are there.)
Roger
PostPosted: Wed Jun 28, 2023 7:32 am
Many years ago a British car had an aluminum front end. Where it was attached it rotted due to electrolysis. Stainless would fix this for attaching. (Doc Brenholtz RIP) Attaching aluminum water pumps etc use Neversieze on the threads to make removal a breeze.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
Users browsing this forum: Google [Bot] and 17 guests
