It is currently Tue Nov 18, 2025 6:48 pm
 Post subject: Turn-signal switch
PostPosted: Mon Jul 24, 2023 12:53 pm
Trying this again on this thread.... 63 Valiant; I cannot figure out how this switch is supposed to work.. move around when you move the turn signal stalk? stay stationary?
Any help or tips appreciated.
 Post subject: Re: Turn-signal switch
PostPosted: Mon Jul 24, 2023 1:25 pm
The C-shaped part on the left and toward the driver should move when you move the signal lever. The rest of the switch needs to be fixed (with 3 screws, I believe) to the rest of the steering column. Hope this helps, or please describe what it is doing. I wonder if the wires on the left are restricting motion, since they should run directly back into the column and not be next to the C-shaped part. Or, maybe something is loose in the column that is letting the whole assembly (all the white plastic parts) move when you move the lever?
Best,
PostPosted: Tue Jul 25, 2023 9:51 am
It was the wires bunched up underneath preventing the switch from fully seating. Moved the wires around as best as I could and finally got it seated. Thank you.
PostPosted: Tue Jul 25, 2023 10:20 am
Super! Congrats.
