| Oil Leak https://mail.slantsix.org/forum/viewtopic.php?t=67385 |
| Author: | Dart270 [ Fri Aug 25, 2023 1:05 pm ] |
| Post subject: | Re: Oil Leak |
They make those boots, but they are hard to replace and you might damage the oddball ball-and-trunion joint. In the past, I was able to take a plastic garbage bag and carefully wrap it around and secure it with zip ties and it worked for 20-30k miles before I switched to a different U-joint setup. Yes, not ideal, but would work for a while. Someone here might have parts or another solution. You can replace the B&T setup with a truck-style slip yoke and special flange that Spicer makes (or made at one point). Lou |
| Author: | SlantSixDan [ Fri Aug 25, 2023 1:59 pm ] |
There is nothing fundamentally the matter with the ball-and-trunnion front U-joint Chrysler used through '65, but at this late date a torn boot is the least of your worries; the joint likely has substantial wear, and rebuilding it is costly. The conversion to the more conventional cross-and-roller type joint is a wise use of repair dollars. The how-to is here. |
| Author: | valleyguy [ Sat Aug 26, 2023 5:47 am ] |
So am I to assume the oil leak is coming from the trans? I ask because I do want to actually drive this car in a week or two... It has not been driven for I don't know how many years. I've never driven it, never moved it out of my garage. wouldn't want to ruin the trans. Second: If I can locate a driveshaft shop (I'm out in the boonies), Can I get them to make me up a complete new unit, front to back, if I give them the measurements and necessary parts, assuming I can find them? |
| Author: | Dart270 [ Sat Aug 26, 2023 10:35 am ] |
No, the leak is from the B&T joint "pot" on the front of the driveshaft. You will not hurt the trans, and short driving as is will not hurt the joint. Yes, they can make a new driveshaft, front to back. Best to take the old driveshaft to them, or answer their questions carefully over the phone (and measure the old driveshaft carefully). Lou |
