rubber valve cover gaskets??
https://mail.slantsix.org/forum/viewtopic.php?t=67480
Page 1 of 2
Author:  Badvert65 [ Thu Oct 26, 2023 7:26 am ]
Post subject:  rubber valve cover gaskets??
I am going to have a run of rubber (Buna-N) valve cover gaskets made for the slant six (early years). I can have them made either 3/16 or 1/4 inch thick. What is the general consensus about which would be the better choice?
Author:  Rick Covalt [ Thu Oct 26, 2023 9:11 am ]
Post subject:  Re: rubber valve cover gaskets??
Is there a big difference in price? I would guess the factory ones are not 1/4" thick, but it may not hurt.
Author:  Badvert65 [ Thu Oct 26, 2023 9:33 am ]
The FelPro rubber gaskets I have measured are 1/8 inch. Not a big difference in manufacturing costs.
Author:  Greg Ondayko [ Thu Oct 26, 2023 9:40 am ]
If they are too thick then the factory bolts may be too short to capture the threads in the head.
1/8 to 3/16 should be plenty in my opinion.
Author:  Dart270 [ Thu Oct 26, 2023 10:27 am ]
Sometimes rockers hit the valve cover slightly with big cams. Having a thick gasket (1/4" or even 3/16") would be nice to alleviate this. I vete for 1/4", but either would be fine.
Thanks!!
Author:  Greg Ondayko [ Thu Oct 26, 2023 11:20 am ]
Good point. I never thought of that Lou, but I have certainly had that happen. I could get some longer bolts/studs with a 1/4" gasket and live with it.
Author:  slantzilla [ Thu Oct 26, 2023 12:05 pm ]
I'd be interested in some 1/4" too.
Author:  Dart270 [ Thu Oct 26, 2023 12:55 pm ]
Man, I wonder how many factory (short-a$$) bolts I have holding valve covers down. Not many...
Go guarter inch!!
Author:  Rick Covalt [ Thu Oct 26, 2023 3:50 pm ]
Agreed! You go Matt! :D
Author:  Reed [ Thu Oct 26, 2023 3:59 pm ]
Go big. There are options for retaining ardware if 1/4 inch is an issue.
Author:  dddDuster [ Thu Oct 26, 2023 5:22 pm ]
I’m in for 1/4”. Will you sell thru your eBay site?
Author:  lgu32 [ Thu Oct 26, 2023 6:11 pm ]
I am happy owner of small stock of Felpro rubber valve cover gaskets. I found them from UK with the part number.
I have found 2 Fel-Pro 1/8" thick gaskets to be enough for my Clifford valve cover. That is because the cast cover is not absolutely straight and because the surface it is not machined but cast.
I have glued the upper gasket with RTV to the cover. The lower gasket is free with no glue. Together with all of this I have ARP studs and nuts for the cover. They are nice as they keep the gasket in a place during installation.
WARNING. Use of extended valve cover screws could cause water leak. The holes are originally blind but with long screws the bottom of the hole is pretty easy to crack. After that the only solution is use (ARP or similar) studs with glue.
Author:  lgu32 [ Thu Oct 26, 2023 6:18 pm ]
I vote for 1/4" gasket but I like to have short bushings installed to the gasket avoiding too tight compression with screws/stud-nuts.
Have you already tested Buna-N in this solution? The data says it has limited heat resistance. Most vulcanized rubbers will continue hardening (vulcanizing) under heat. Some will come "hard as a glass". I thing a hard silicone sheet would be ideal material. I have such a seal in a distilling pot and it has not changed its elastic features at all in use.
Author:  hyper_pak [ Fri Oct 27, 2023 8:03 am ]
I don't want them much thicker than the stock.
Don't want them crushing out of the cover.
You had asked about other products, this got me thinking.
How hard would a valve cover spacer be to make?
3/8 I would think would be fine.
Just an idea.
Author:  SlantSixDan [ Fri Oct 27, 2023 12:13 pm ]
Strikes me this (also see here) could readily be sandwiched between two gaskets to make what you have in mind, no?
Page 1 of 2 All times are UTC-08:00
