It is currently Mon Nov 17, 2025 7:14 am
 Post subject: Rear main seal
PostPosted: Mon Oct 30, 2023 5:04 pm
Car Model: 86 dodge d100
I been having an annoying oil leak that I tracked down to be the rear main seal (weeping slightly) only while running. I initially thought it was the oil pan gasket so I redid that but still was weeping. I believe I installed the rear main seal wrong due to it riding on the knurled part of the crank shaft (see pic). If i flip the seal around the lip of the seal appears to not ride in the knurled part. My question is did i still install it correctly initially or do I have to reverse it from how it is currently installed when i pull the crank (lip riding toward flywheel side). This is a fresh rebuild with less than 800 miles and wasn't leaking except for the last 50 miles roughly.
 Post subject: Re: Rear main seal
PostPosted: Wed Nov 01, 2023 3:11 pm
Besides way too much silicone, something looks odd about that seal. But, the sharp edge of the lip should face the engine side.
PostPosted: Wed Nov 01, 2023 4:05 pm
Online
This picture shows how the seal is pressurized by crankcase pressure.
It's not a slant, but the seal is installed correctly.
PostPosted: Wed Nov 01, 2023 5:35 pm
Gotchya, makes sense thanks for the pic.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
