It is currently Tue Nov 18, 2025 3:04 am
PostPosted: Thu Dec 28, 2023 9:13 am
Working on my '62 Block Here..
What Year Did Chrysler switch from the Larger Cam Plug at the rear of the block to the 2 9/64"Ø plug(Dorman 555-065) from the larger plug?
(excerpt from my '62 valiant restoration blog below)
I had a feeling that I would need the original Cam plug for the back of the block, so I saved it. I had this happen to me before when I was working on a '64 Truck block a while ago - some of the early blocks are machined for a larger rear cam plug - meaning the 2 9/64" Ø - Dorman 555-065 Plugs do not fit. - Too Small. My guess is the early cast iron blocks (this is a '62 Block) and the AL blocks use this larger plug?
Any TSB, Information or insight is appreciated!
PostPosted: Thu Dec 28, 2023 10:37 am
Good catch on saving it!
PostPosted: Fri Dec 29, 2023 12:57 pm
Looks like new plug ø for '63 on the iron blocks. That would make sense, because it corresponds to the new iron block casting numbers for '63—and that mysterious conrod oil hole about-face we were talking about.
PostPosted: Fri Dec 29, 2023 1:49 pm
Great, thanks for the Info.
Now I will know to never throw out those big cam plugs!
PostPosted: Fri Dec 29, 2023 2:56 pm
Why not just buy new? Last line item here in brass, for example, or fourth up from the bottom here in stainless.
PostPosted: Fri Dec 29, 2023 3:08 pm
Even Better!
Thank you sir!
