Turning the crank
https://mail.slantsix.org/forum/viewtopic.php?t=67521
Page 1 of 1
Author:  valleyguy [ Tue Nov 28, 2023 7:27 am ]
Post subject:  Turning the crank
My 63 VAliant: How do I turn the crankshaft by hand? very little room between the radiator and the crank pulley.
Author:  Greg Ondayko [ Tue Nov 28, 2023 7:39 am ]
Post subject:  Re: Turning the crank
Use the fan blade to turn it, and be sure you have the belt and alternator installed. Hand tension the belt more if it slips.
Works great unless you have a declutching fan, which should not be an issue with your car.
Author:  hyper_pak [ Tue Nov 28, 2023 8:09 am ]
Manual?
You can put it in gear, and pull or bump the car and it will turn.
Plugs out and it turns eay.
