| Power sterring hose for my 1970 Dart https://mail.slantsix.org/forum/viewtopic.php?t=67572 |
| Author: | Beitie [ Sat Dec 30, 2023 12:42 pm ] |
| Post subject: | Power sterring hose for my 1970 Dart |
Hey everyone, I'm trying to find the proper power steering high pressure hose for my 1970 Dodge Dart. This car has the 225 Slant Six, with A/C. I am not sure how to verify what kind of pump I have, and all the pictures of power steering hoses I've seen when looking for a replacement have not matched what I have currently in the car. Any help with this would be appreciated.
| Author: | SlantSixDan [ Sat Dec 30, 2023 1:44 pm ] |
| Post subject: | Re: Power sterring hose for my 1970 Dart |
Here y'go. If the fitting at the steering gearbox end doesn't look like it'll match up, you may need to unscrew/remove a thread adapter already screwed into the gearbox. |
| Author: | Beitie [ Sat Dec 30, 2023 4:37 pm ] |
Thanks Dan! If this could possibly help anyone else out in the future and the link doesn't work, I'm purchasing the Edelmann 80127 power steering hose. |
| Author: | Beitie [ Sun May 26, 2024 6:38 pm ] |
Update on this topic here. The Edlemann 80127 wasn't quite the correct one. It had a male end that needed to be a female end for hooking up to the steering pitman arm. So I ended up purchasing an Edlemann 70337 from Rock Auto. I had to manipulate the bends of the hose a little bit, but it did fit, and seems to be working well. |
| Author: | SlantSixDan [ Mon May 27, 2024 2:17 pm ] |
Quote: Update on this topic here. The Edlemann 80127 wasn't quite the correct one. It had a male end that needed to be a female end for hooking up to the steering pitman arm The hose doesn't connect to the pitman arm, it connects to the steering gearbox. And I told you exactly how to deal with this mismatch: unscrew the fitting threaded into the top of the steering gearbox, then the male end of the hose goes right in. ¯\_(ツ)_/¯
| Author: | Greg Ondayko [ Tue May 28, 2024 1:57 pm ] |
I have bought those edlemann hoses before and sometimes the required adapter fitting is in the bag with the new hose. |
| Author: | Beitie [ Fri Jun 14, 2024 8:21 pm ] |
I'm fairly sure that the hose I was replacing is the original equipment hose from Dodge, and the 70337 had the same connections that the OEM used, and I wanted to keep it that way. Thanks for correcting me on the steering box part. I get lost with words at times. |
