| Camshaft Master spreadsheet? https://mail.slantsix.org/forum/viewtopic.php?t=67585 |
Page 1 of 2 |
| Author: | Greg Ondayko [ Wed Jan 10, 2024 11:53 am ] |
| Post subject: | Camshaft Master spreadsheet? |
Hello folks, was there a master camshaft spreadsheet for stock / Mopar Performance and Custom / Modified slant 6 cams somewhere? I checked the Engine FAQ section but Have not yet found what I thought I was looking for. Thank you, Greg |
| Author: | Dart270 [ Wed Jan 10, 2024 12:49 pm ] |
| Post subject: | Re: Camshaft Master spreadsheet? |
I do not recall that, but maybe it is there. I have a bunch of specs (20-30 cams) that I could add/donate. Nothing stock, though. Lou |
| Author: | Greg Ondayko [ Wed Jan 10, 2024 1:12 pm ] |
Alright I might just call / chat with you Lou, I am deciding on what to put in my '62 Valiant Wagon engine. I Think the '64 dart cam you speced for me is great, but I fear it will run too hot with a stock type radiator. I wanted to put the mopar performance .490 cam in there but realized I gave my .490 away. I have A few .528 mopar cams but I am realizing that I probably do not like that cam as much as I once used to. Greg |
| Author: | volaredon [ Wed Jan 10, 2024 3:26 pm ] |
I forgot where but somewhere here is one for all that Oregon cams offers |
| Author: | Greg Ondayko [ Wed Jan 10, 2024 4:01 pm ] |
Yes I have that one. Was looking for known factory cams, mopar performance and other known cam profiles. Greg |
| Author: | Rick Covalt [ Wed Jan 10, 2024 5:58 pm ] |
I think Seymour put a list together in one of the SSRN that had a lot of the smaller /factory cams in it as well as race cams. I may have it printed off somewhere? |
| Author: | slantzilla [ Wed Jan 10, 2024 6:48 pm ] |
The .528 Mopar cams are well known for killing oil pump gears. |
| Author: | Greg Ondayko [ Wed Jan 10, 2024 6:50 pm ] |
Quote: The .528 Mopar cams are well known for killing oil pump gears.
and thus Engines..I have been lucky with the one I have in the '69 Dart for years. Greg |
| Author: | slantzilla [ Thu Jan 11, 2024 7:46 am ] |
I believe it was the last batch made. I had one, op gear lasted 800 miles. Too bad because the cam makes great power. |
| Author: | Killer6 [ Thu Jan 11, 2024 8:03 am ] |
Quote: I believe it was the last batch made. I had one, op gear lasted 800 miles. Too bad because the cam makes great power.
Dennis, do You recall when that batch was made, & do You still have the failed cam?Thx, Jim K6 |
| Author: | Rick Covalt [ Thu Jan 11, 2024 9:23 am ] |
After that failure (2 or3 times) Ryan put the Erson High Flow AM in his Dart and ran it for over 10 years. It is similar in size I think and ran well.
| Author: | slantzilla [ Thu Jan 11, 2024 9:42 am ] |
Quote: Quote: I believe it was the last batch made. I had one, op gear lasted 800 miles. Too bad because the cam makes great power.
Dennis, do You recall when that batch was made, & do You still have the failed cam?Thx, Jim K6 Terry Littlejohn has that cam now. |
| Author: | Rick Covalt [ Thu Jan 11, 2024 6:06 pm ] |
That is about when Ryan's would have been too. |
| Author: | Charrlie_S [ Fri Jan 12, 2024 5:10 am ] |
I have one that wiped a lobe. |
| Author: | Dart270 [ Fri Jan 12, 2024 7:51 am ] |
The 0.528" I sold Greg that's been running in his Dart was from 1994-1995. No problems, apparently. Lou |
| Page 1 of 2 | All times are UTC-08:00 |
