It is currently Mon Nov 17, 2025 11:30 am
PostPosted: Wed Jan 10, 2024 11:53 am
Hello folks, was there a master camshaft spreadsheet for stock / Mopar Performance and Custom / Modified slant 6 cams somewhere?
I checked the Engine FAQ section but Have not yet found what I thought I was looking for.
Thank you, Greg
PostPosted: Wed Jan 10, 2024 12:49 pm
I do not recall that, but maybe it is there. I have a bunch of specs (20-30 cams) that I could add/donate. Nothing stock, though.
PostPosted: Wed Jan 10, 2024 1:12 pm
Alright I might just call / chat with you Lou,
I am deciding on what to put in my '62 Valiant Wagon engine. I Think the '64 dart cam you speced for me is great, but I fear it will run too hot with a stock type radiator.
I wanted to put the mopar performance .490 cam in there but realized I gave my .490 away.
I have A few .528 mopar cams but I am realizing that I probably do not like that cam as much as I once used to.
PostPosted: Wed Jan 10, 2024 3:26 pm
I forgot where but somewhere here is one for all that Oregon cams offers
PostPosted: Wed Jan 10, 2024 4:01 pm
Yes I have that one. Was looking for known factory cams, mopar performance and other known cam profiles.
PostPosted: Wed Jan 10, 2024 5:58 pm
I think Seymour put a list together in one of the SSRN that had a lot of the smaller /factory cams in it as well as race cams. I may have it printed off somewhere?
PostPosted: Wed Jan 10, 2024 6:48 pm
The .528 Mopar cams are well known for killing oil pump gears.
PostPosted: Wed Jan 10, 2024 6:50 pm
and thus Engines..
I have been lucky with the one I have in the '69 Dart for years.
PostPosted: Thu Jan 11, 2024 7:46 am
I believe it was the last batch made. I had one, op gear lasted 800 miles. Too bad because the cam makes great power.
PostPosted: Thu Jan 11, 2024 8:03 am
Dennis, do You recall when that batch was made, & do You still have the failed cam?
Thx, Jim K6
PostPosted: Thu Jan 11, 2024 9:23 am
After that failure (2 or3 times) Ryan put the Erson High Flow AM in his Dart and ran it for over 10 years. It is similar in size I think and ran well.
PostPosted: Thu Jan 11, 2024 9:42 am
Thx, Jim K6
My failure was in the early 2000's and I am sure the cams had already been discontinued from Mopar.
Terry Littlejohn has that cam now.
PostPosted: Thu Jan 11, 2024 6:06 pm
That is about when Ryan's would have been too.
PostPosted: Fri Jan 12, 2024 5:10 am
I have one that wiped a lobe.
PostPosted: Fri Jan 12, 2024 7:51 am
The 0.528" I sold Greg that's been running in his Dart was from 1994-1995. No problems, apparently.
Users browsing this forum: Google [Bot] and 20 guests
