| Timing, and getting this thing on the road again https://mail.slantsix.org/forum/viewtopic.php?t=67627 |
| Author: | perkinsbl [ Fri Feb 09, 2024 2:16 am ] |
| Post subject: | Timing, and getting this thing on the road again |
Hey so replaced my timing chain set. Crank mostly staying in place, but when I put it together crank bearings is either -20 degrees, and the timing gears are *to*. . Replaced distributor too. Nylon gear was issue, not timing. Sucks.. thinking mark it, see where I can get distributor close to #1.. hope for best, otherwise? Camera to #1 firing order for when tdc (top dead veter) |
| Author: | volaredon [ Fri Feb 09, 2024 4:59 am ] |
| Post subject: | Re: Timing, and getting this thing on the road again |
Quote: Hey so replaced my timing chain set. Crank mostly staying in place, but when I put it together crank bearings is either -20 degrees, and the timing gears are *to*. . Replaced distributor too. Nylon gear was issue, not timing. Sucks.. thinking mark it, see where I can get distributor close to #1.. hope for best, otherwise? Camera to #1 firing order for when tdc (top dead veter)
Your post doesn't make sense. "Crank bearings -20*"?
| Author: | Dart270 [ Fri Feb 09, 2024 6:16 am ] |
Agreed. Please reword and expand your questions so we can help you. Thanks, Lou |
| Author: | Greg Ondayko [ Fri Feb 09, 2024 7:02 am ] |
Maybe the O.P. has installed 0.020" undersized crankshaft bearings? This will have no "bearing" on the timing issues presented here. Greg |
| Author: | Rick Covalt [ Fri Feb 09, 2024 4:56 pm ] |
Quote: Please reword and expand your questions so we can help you.
Yes we will be happy to help! |
