It is currently Mon Nov 17, 2025 6:12 am
PostPosted: Sat Jun 29, 2024 12:55 am
My passenger door is not closing easily. I need to lift the door a little to close. Car was sitting on blocks for a few weeks and the door may have dropped a little.
How can I fix this problem? A door latch adjustment; if so, how would I adjust the door latch?
Thanks.
PostPosted: Sat Jun 29, 2024 1:02 pm
If you (1) need to and (2) can lift the door a little to get it to close, that points at wear in your door hinges and pins. Those will have to be refurbished in order for your door to swing closed without lifting.
