| Hyper Pak Throttle Bracket https://mail.slantsix.org/forum/viewtopic.php?t=67710 |
| Author: | Greg Ondayko [ Thu Apr 11, 2024 11:07 am ] |
| Post subject: | Re: Hyper Pak Throttle Bracket |
Looks good. My hyper pack does not currently use a twisty rod throttle. I also thought the twisty rods on the 1bbl cars were in use until 1966? maybe 1965 and 66 used the throttle cable, as I am not very familiar with those years in OE slant trim. I guess you need to make a lot more linkage if you want to run the carb in the other direction with the throttle rod. Did the Hyperpack come with a longer rod to replace the one barrel rod, or make your own? Get some measurements and I can Make a CAD Drawing of it. looks like 3 ~ 5/16" Holes and one bend on a triangle. I can give the drawing to you or share it if you want to give away the IP. Greg |
| Author: | hyper_pak [ Thu Apr 11, 2024 11:48 am ] |
Yes uses a much longer rod, have not found that. I made the one on Lancersaurus. I don't see the need to change the direction. The throttle bores are sized for the 3083S Carb, smaller toward the engine. |
