| Which clutch?? https://mail.slantsix.org/forum/viewtopic.php?t=67742 |
| Author: | tattoosteve99 [ Thu Apr 25, 2024 8:39 pm ] |
| Post subject: | Which clutch?? |
Two types of clutches are available. 3 lever style and diaphragm style. Which one is best? 1978 d100 with slant six and 3 speed manual a230 trans. |
| Author: | Greg Ondayko [ Fri Apr 26, 2024 4:49 am ] |
| Post subject: | Re: Which clutch?? |
Well, if you are looking at a Rockauto Calalog / website. that diaphragm unit is probably mislabeled or misapplied. Either pressure plate will work fine in a stock application. Usually for the slant 6, the diaphragm unit is a custom/aftermarket/ use of another oe application to fit onto the slant 6 flywheel. All of the factory OE slant 6 pressure plates would have been the 3-finger style. What is your Flywheel ring gear tooth count? Greg |
| Author: | tattoosteve99 [ Mon May 06, 2024 4:30 am ] |
That’s a good question Greg. I’m not really sure. |
| Author: | Greg Ondayko [ Mon May 06, 2024 4:40 am ] |
Quote: That’s a good question Greg. I’m not really sure.
Post a picture of your bell housing/starter area or count the teeth on your flywheel. Trucks did have a few bell housing/flywheel configurations from what I can tell. Greg |
