| Galling on pump flange A904 https://mail.slantsix.org/forum/viewtopic.php?t=67758 |
| Author: | Stroker41665 [ Wed May 15, 2024 6:20 am ] |
| Post subject: | Galling on pump flange A904 |
How do you all feel about this bit of bad work on the pump flange. Its at the top of the trans, looks like a bilt was used to push out the pump Usable? |
| Author: | Greg Ondayko [ Wed May 15, 2024 6:40 am ] |
| Post subject: | Re: Galling on pump flange A904 |
There is no picture here. Depends if it is just the pump bushing that is goobered up or if the damage got into the pump rotor housing / bearing support area or not. I would just get a whole new front pump assembly from A and A transmission in Camby Indiana and be done with the whole thing. Greg |
| Author: | Stroker41665 [ Wed May 15, 2024 9:25 am ] |
| Author: | Stroker41665 [ Wed May 15, 2024 9:28 am ] |
Trying to post image. Its a mark on the trans housing near on the top by a bolt hole where it seems a bolt was used to force the pump out of the trans. |
| Author: | Stroker41665 [ Wed May 15, 2024 9:35 am ] |
| Author: | volaredon [ Wed May 15, 2024 10:53 am ] |
Still ain't coming up. Sounds like it's the trans case itself not the pump I have an engine/ trans core place by me I've bought internal trans parts from before. Planetaries, pumps, drums etc. Near the top/ so not by the fluid port holes where fluid passes from pump to case... I think I know what you're talking about, and approximately where... There are 2 pump housing holes tapped the next size over what the bolts are that hole the pump in.. meant for a slide hammer to get the pump out. Is this divot you mentioned in line with e pump mount hole? If the aluminum is displaced or raised from the flat surface I'd dress it down flat the best I could without creating a crater and chase that pump mount hole, put the gasket on the pump and the outer o ring, and send it. |
| Author: | Stroker41665 [ Wed May 15, 2024 2:57 pm ] |
That's exactly where the problem is. Thanks for the advice. |
