| 3278 S Carb Info? https://mail.slantsix.org/forum/viewtopic.php?t=67787 |
| Author: | Greg Ondayko [ Mon Jun 10, 2024 7:02 pm ] |
| Post subject: | 3278 S Carb Info? |
Can anyone give me some insight on how an air filter housing mounts on a Carter BBS 3278 S Carb? It does not have a typical wire bail or a provision for one. I am guessing it is like the 1964 Dart with a 273 my da d has where it uses a sort of clamp attachment? maybe for an oil bath type air filter? Thanks Sages! |
| Author: | SlantSixDan [ Tue Jun 11, 2024 6:16 am ] |
| Post subject: | Re: 3278 S Carb Info? |
That's for a 1962 Dodge truck with 170 engine, manual transmission, and manual choke. You're correct, it was designed to take an air cleaner with a clamp-band type attachmentâan oil-bath item, like this. Different/smaller size than the similar 2bbl setup used on pre-'66 V8s. |
| Author: | Greg Ondayko [ Tue Jun 11, 2024 7:19 am ] |
Thanks again for the D'answer. Greg |
