Flywheel torque spec
https://mail.slantsix.org/forum/viewtopic.php?t=67790
Page 1 of 1
Author:  J S Goldman [ Thu Jun 13, 2024 4:54 pm ]
Post subject:  Flywheel torque spec
does any know the torque spec of the flywheel bolts on a stock 1966 225?
Author:  Dart270 [ Fri Jun 14, 2024 1:13 am ]
Post subject:  Re: Flywheel torque spec
If you mean flywheel to crank hub, then I believe it is 55 ft lbs. However, I ALWAYS torque mine to 65-75 ft lbs and use red loctite so they do not vibrate loose.
Author:  J S Goldman [ Fri Jun 14, 2024 6:43 am ]
Thank You
