| Easy removal of Ebrake handle solution https://mail.slantsix.org/forum/viewtopic.php?t=67823 |
| Author: | gearhead [ Mon Jul 08, 2024 10:22 pm ] |
| Post subject: | Easy removal of Ebrake handle solution |
Hi guys: For thirty years I have been annoyed by my broken emergency brake lever. I have cut my head more than I can count on the sharp metal where the plastic broke away. I've tried removing the roll pin various times over the years with no success. I have a machine shop and could've made something, but never got around to it...now the car is torn down and I want to finally fix this issue. I started looking online at roll pin removal presses and came across a motorcycle chain breaker at Harbor Freight that looked like it might work or be easily modified so that it would. So I bought one for I think $14.95 or less. It worked perfect with no modification. The factory roll pin is 3/16"(.1875") and the press is .157" pin press. Anyway, if any of you have ever wanted an easy way to remove the roll pin, here is a $15 example. ![]() Thanks Gearhead AKA Karl |
| Author: | Dart270 [ Tue Jul 09, 2024 3:14 am ] |
| Post subject: | Re: Easy removal of Ebrake handle solution |
Nice idea and thanks for sharing, Karl. Lou |
| Author: | Rick Covalt [ Tue Jul 09, 2024 3:26 am ] |
Now we just need someone to make us a nice heavy aluminum handle to replace the plastic with! |
