It is currently Mon Nov 17, 2025 6:47 pm
PostPosted: Mon Jul 08, 2024 10:22 pm
Car Model: 1964 Valiant 2dr post
Hi guys:
For thirty years I have been annoyed by my broken emergency brake lever. I have cut my head more than I can count on the sharp metal where the plastic broke away.
I've tried removing the roll pin various times over the years with no success. I have a machine shop and could've made something, but never got around to it...now the car is torn down and I want to finally fix this issue. I started looking online at roll pin removal presses and came across a motorcycle chain breaker at Harbor Freight that looked like it might work or be easily modified so that it would.
So I bought one for I think $14.95 or less. It worked perfect with no modification. The factory roll pin is 3/16"(.1875") and the press is .157" pin press.
Anyway, if any of you have ever wanted an easy way to remove the roll pin, here is a $15 example.
Thanks
Gearhead
AKA Karl
64 GTO...10.80's@122 on street radials
Destroked 455, Qjet, stock ign, 2400 stall
64 Valiant
Old 225, 4spd, 2.92-8.75, 2bbl, headers
dual 2.25"
PostPosted: Tue Jul 09, 2024 3:14 am
Nice idea and thanks for sharing, Karl.
PostPosted: Tue Jul 09, 2024 3:26 am
Now we just need someone to make us a nice heavy aluminum handle to replace the plastic with! :D :D
