| Low oil pressure ... do i have a big problem? https://mail.slantsix.org/forum/viewtopic.php?t=67887 |
| Author: | ScampNYC [ Thu Aug 22, 2024 7:45 pm ] | ||
| Post subject: | Re: Low oil pressure ... do i have a big problem? | ||
Heres the mystery object
Another view of the object
| Author: | ScampNYC [ Thu Aug 22, 2024 7:47 pm ] | ||
The car as I found it. I replaced the fuel tank and all fuel lines before getting it running.
| Author: | mcnoople [ Fri Aug 23, 2024 5:59 am ] |
Your object is likely part of the old oil filter. I don't recognize it personally. I will say put an actual oil pressure gauge on the car to see what it is at, your frozen fitting is I believe 3/8 npt. Get a normal TEE from the plumbing section of your local hardware store and use thread tape on the fittings. But be advised that in the owners manual from when they built these car that chrysler believes it is perfectly fine and normal for the oil pressure light to flicker when fully warmed up in gear in hot weather. The engines can idle so low stationary in gear that they only build 4 or so psi, hence the need of an actual gauge to see what pressure is when driving. You don't need the gauge to be permanent just a diag tool to determine the engines health. |
| Author: | SlantSixDan [ Fri Aug 23, 2024 1:42 pm ] |
That's not part of the oil filter, no; it's the valve plate from the check valve in the oil filter adapter screwed into the middle of the oil filter mount pad part of the oil pump. That check valve's nominal job is to prevent oil leaking down out of the filter after engine shutdown. The spring you see in the adapter used to hold the plate against the rim at the "ceiling" of the adapter, but it has come apart. There used to be a steel standpipe about 3 inches long pressed into that adapter; it appears to have gone missing sometime in the last 53 years, and with that gone, the valve components had enough more wiggle room to escape. Replacement standpipe/valve assemblies are no longer available; new oil pumps come with just a plain, hollow adapter. Remove the spring and discard it and that escaped plate, leaving you with a hollow adapter. The valve and standpipe's function can be duplicated by using a filter with an inbuilt standpipe, that is Fleetgard LF701 (best available filter of this type), or Wix 51806. As to the problem you're experiencing: don't panic just yet. Service the oil pressure relief valve to make sure it's doing its job and isn't stuck partway open, as described in these two threads: thread 1, thread 2. Oil pressure sending unit is 3/8" Dryseal thread. The sender is another likely cause of this oil light behaviour; it might go away just by replacing the sender (but you should still service the relief valve). Alternate location to put in a mechanical pressure gauge: the 3/8" dryseal-threaded pipe plug on the passenger side of the block, near the rearmost extent of the oil galley. |
| Author: | ScampNYC [ Sun Aug 25, 2024 10:06 am ] |
Thanks, Dan! Very encouraging. Interesting about the standpipe. I wonder if its possible that it came off with the extreme amount of torque I had to apply to get the seized oil filter off. |
| Author: | SlantSixDan [ Sun Aug 25, 2024 10:42 am ] |
No. It doesn't touch the filter. It just loosened up and came off sometime in the past. |
| Author: | Jase [ Tue Aug 27, 2024 7:39 am ] |
I had lower oil pressure upon startup last year. Rather than 45 PSI, I had 38 or 40 PSI on a cold start. I impulsively changed the oil, and filter, and found that the stand pipe was slightly loose.. Not sure if the loose stand pipe was causing lower oil pressure, of if the filter was going into bypass.. It was low mileage oil, and a new filter, and the oil pan has been removed and cleaned to address an oil leak at the front of the engine.. so I don't think the filter was going into bypass due to being plugged.. Seeings that I run the 51806 filter, I may remove the oil pump stand pipe on the next oil change.. |
