| Help with transmission swap if it it fits. https://mail.slantsix.org/forum/viewtopic.php?t=67914 |
| Author: | Slantsix83 [ Mon Sep 09, 2024 7:11 pm ] |
| Post subject: | Help with transmission swap if it it fits. |
I have a 1983 d150 slant six with a ford 4 speed transmission not sure what type. I saw on ad on Facebook of this guy selling a New Process NP435 4-speed transmission manual with bell housing for Dodge flywheel, clutch, pressure plate, driveshaft, PTO (Power Take Off) gearbox. Included would this fit my slant six if not what would I need to do. He says it came from the factory on a 440. Also is this a granny transmission or would acceleration be quicker. |
| Author: | Rick Covalt [ Tue Sep 10, 2024 6:36 am ] |
| Post subject: | Re: Help with transmission swap if it it fits. |
No it won't fit. If it was on a 440 then the belhousing, flywheel...etc is different than a Slant 6. |
| Author: | volaredon [ Tue Sep 10, 2024 10:24 am ] |
That NP435 was used in both Dodge and Ford What "Ford trans" is in your truck? The 435 had a removable bell housing, with the right bell housing and flywheel that trans could go behind a /6. |
| Author: | Slantsix83 [ Tue Sep 10, 2024 4:02 pm ] |
Could I get that all separately so it can fit
| Author: | Slantsix83 [ Tue Sep 10, 2024 4:03 pm ] |
No clue all I know is that it's a 4 speed. Couldn't really ever find any information on it what used parts could I find for the transmission to fit.
| Author: | hank2 [ Tue Sep 10, 2024 11:25 pm ] |
Your '83 D150 (2wd) slant would have had an A833OD 4 speed with super tall .71/1 top gear. Anything 4wd (W100 and up) and any D/W250, D/W350 would have had the A435 heavy duty trans with grannie 1st gear. |
| Author: | Slantsix83 [ Wed Sep 11, 2024 5:48 am ] |
I really don't think it's the A833 I'll take pictures of it when I change out the throw out bearing. Because when I replaced the clutch I was told it wasn't a dodge but a ford clutch.
| Author: | Charrlie_S [ Wed Sep 11, 2024 6:39 am ] |
For sure not a 833 OD. That is a "top loader". |
| Author: | Slantsix83 [ Wed Sep 11, 2024 7:16 am ] |
I've been having issues trying to id the transmission. All I know is that it's a ford since it has a ford clutch in it.
