It is currently Tue Nov 18, 2025 9:20 am
PostPosted: Fri Mar 07, 2025 2:36 pm
Long story short I cant identify my transmission so i can use a drive by cable to measure the speed. And i dont want to spend $400 to keep my oem one. Just not worth the money for me. Was wondering if anyone has tried this gps speedo and how they retrofited it inside the dash. Since this speedo is 3 3/8 inches diameter and the stock is 5. Any help would be great.
PostPosted: Fri Mar 07, 2025 2:45 pm
Why can't you identify the trans? Can you post a picture?
Is it an automatic, or a standard shift?
PostPosted: Fri Mar 07, 2025 2:59 pm
I have on previous post. Its some sort of 80s Ford transmission.
PostPosted: Fri Mar 07, 2025 3:43 pm
I saw that post, but only saw a picture of the shifter. Can you do a picture of the trans itself? From the looks of the shifter, it should be a A-833OD trans.
PostPosted: Fri Mar 07, 2025 4:15 pm
PostPosted: Fri Mar 07, 2025 4:36 pm
I don't recognize it from that picture. Do you have any more pictures? where the shifter connects, where the speedo cable connects, etc ? Is it a 3 speed or 4 speed?
PostPosted: Fri Mar 07, 2025 4:46 pm
I dont have any more pictures. But its 4 speed. Shifter connects in the top middle of the transmission. And it has no Shifter cable.
PostPosted: Fri Mar 07, 2025 7:57 pm
It's a Tremac RTS TOD, from a 1980s F-150.
And I'm not a Ford guy, and know nothing about Ford transmissions.
Now you can go figure out what transmission drive gears they used and decide what you want to do.
– Eric
PostPosted: Sat Mar 08, 2025 2:46 am
OK. I'm at a loss, here. Sorry I can't be of any help.
PostPosted: Sat Mar 08, 2025 3:41 am
OK, I got this thread off track.
Slantsix83 can you post some more info or a picture on the unit in question? The GPS.
PostPosted: Sat Mar 08, 2025 5:43 am
Get one of these:
https://www.summitracing.com/parts/dak-ecd-200bt-1
Drive it with one of these:
https://www.summitracing.com/parts/dak-gps-50-2
And Use one of these to get a quicker GPS lock:
https://www.summitracing.com/parts/dak-600041
This model I picked because the '64 Dart has a 5/8" thread on connector like the GM does.
For your Clicp on style Speedo you may need a custom cable or some sort of adapter. I am not sure If DD makes a Mopar specific Cable end or if another part # of the 200Bt will work for you. Do your research or call summit support.
Either way it will be cheaper to get a speedometer cable for your existing Transmission and speedometer combination.
PostPosted: Sat Mar 08, 2025 6:07 am
For $500 I would just duct tape my I phone to the dash! :D :D
PostPosted: Sat Mar 08, 2025 6:23 am
– Eric
Id have to pull down the transmission wouldnt i?
PostPosted: Sat Mar 08, 2025 7:12 am
ELING Warranted 160 MPH Car Motorcycle GPS Speedometer Odometer Gauge for Auto Motorbike Tractor Truck with Backlight 3 3/8" 12VDC 24 Volt
On Amazon it's a universal
PostPosted: Sat Mar 08, 2025 7:13 am
Get one of these:
I cant justify the cost of that
Users browsing this forum: Google [Bot] and 7 guests
