It is currently Mon Nov 17, 2025 12:00 am
PostPosted: Wed Nov 12, 2025 4:39 pm
Since my original install of MSII (2008) it works well for my needs (batch fired multi-port injection) and full (single) coil control by the MS II via a OE type Slant 6 Distributor.
I updated the firmware from 2008 to ~2019 I think about 6 years ago. The firmware update added so much more functionality in tuner studio / MSII.
The CL Idle control works well except for some hunting issues on a ~ medium warm restart.. It will hunt and oscillate for a few seconds; however if i give it just a bit foot throttle angle, the hunting vanishes when CL Idle shuts off.
What I am asking here is without blindly playing with the P, I, D settings, (as every other idle situation is very good - not 2020 OE new car good, but good enough for me) how to I tune out the "hunt/oscillate" in the P, I, D Settings?
Thank you,
PostPosted: Wed Nov 12, 2025 5:01 pm
Replace fuel injection with BBD. :mrgreen:
PostPosted: Wed Nov 12, 2025 6:18 pm
I did it the other way 'round sir!
This is the fuel injection sub-forum 'ya know!
PostPosted: Fri Nov 14, 2025 4:01 am
I knew I got lost somehow! :D
PostPosted: Sun Nov 16, 2025 1:15 pm
Greg,
Check the ignition advance table to verify that the idle oscillation is not due to the ignition advance table adding advance and causing the RPM run up, having the rpm too high the ecm cuts fuel dragging the rpm down, the ignition then advanced causing the oscillation.
I too have my slant powered ms controlled 68 Barracuda starting and driving like a modern car.
Just turn the key, no throttle added and it starts, idles down as it warms.
I ‘messed’ with the PID to get where I am.
And messed with is basically what I did.
1) made one adjustment at a time and then took the time to determine if there was a difference
2) kept good notes on what was changed so I could go back and not run myself in circles.
I don’t currently have access to my notes or the car so I can’t be more exact on what I did.
There are You Tube videos that provide guidance of what each element of PID does that were helpful.
