Wiring the Microsquirt
https://mail.slantsix.org/forum/viewtopic.php?t=67958
Page 1 of 2
Author:  kesteb [ Mon Oct 21, 2024 12:50 pm ]
Post subject:  Wiring the Microsquirt
Well I am working on the wiring for the Dart and I am finally starting in on the Microsquirt stuff. This is a good set of diagrams which breaks down the various subsystems for easy digestion.
https://thedubshop.com/microsquirt/
Of course this for a VW flat 4, but it shouldn't be too hard to interpolate to a \6.
One on the implications from the "Main Power Circuit" section is that this system can take a max of around 60 amps. The other is that you may not want to use the "Fuel Pump Relay" to power the whole system. The other is that I should use a separate relays for the LS coils and the injectors.
Does anybody know if the Microsquirt can make use of a knock sensor and actually adjust the ignition based on it? The manual seems to suggest that it can only collect and display.
Author:  MadScientistMatt [ Tue Oct 22, 2024 12:41 pm ]
Post subject:  Re: Wiring the Microsquirt
You'd need an external box such as a KnockSenseMS to read the sensor. Knock sensing on aftermarket EFI with top notch knoc detection hardware is often nowhere near as good as what OEMs can pull off, largely because tuners don't have the budget to grenade a half dozen engines on the dyno to develop a detailed acoustic signature for knock. The best you can get is an extra layer of protection.
Author:  Greg Ondayko [ Wed Oct 23, 2024 11:09 am ]
as Matt says, if the acoustic signature is off it will throw those ignition calculations off quite a bit I would surmise.
Author:  Dart270 [ Wed Oct 23, 2024 2:44 pm ]
Creep up on your tune at the track (timing - start low, and mixture - start fat) and look at spark plugs for aluminum bits. Use water/meth injection or a big intercooler...
Author:  kesteb [ Sat Oct 26, 2024 11:28 am ]
It is interesting that there are a least 3 different charts on wire gauge and amp load for automotive usage, none of which match. All of them are nicely laid out for wire length and temperature. If I compare those charts to what various OEMs have actually done they don't match very well. So the answer to how much amperage can a 10g wire handle is hard to determine.
Sigh, frustrating.
Anyway, I have a pair of EATON fuse/relay boxes and a PDM from an Astro van. The EATON boxes use the Metric pak 280 terminals and the PDM use Metric Pak "800 series" terminals. So parts are readily available.
I could power the whole Mircosquirt package from the PDM and add such things as a fused link to charge the battery, relays for the lights and power the rest of the car. This package can handle several hundred amps. And appears to have a 4g input wire connection. and 5 18g ground leads for the 5 relays. When I sit the module onto the inner fender, it looks like GM went out of their way to design it for a '65 Dart. But the wiring would not match the wiring diagram from the above site.
On the other hand the EATON modules are rated a 70 amps a piece and I could wire the Microsquirt exactly like the diagrams.
How important is it to follow the diagram?
Author:  kesteb [ Wed Nov 06, 2024 5:53 pm ]
After much head scratching, I decided to use the Eaton boxes (#15305-2). These are 10 circuit boxes with five circuits for relays. They handle 80 amps. There will be one for the Microsquirt and one for the chassis. I will fuse them at 60 amps and wire them to a power source with 8g wire. Probably a 120 amp Nippo Denso alternator mounted in the A100 van location. No, I am not removing the factory fuse box.
The chassis's box will have a fuse for the 12g wire that powers the car, with fused relays for the headlights.
The Microsquirt box will have relays for the fuel pump, LS coils and the injectors. The rest of the circuits will use the spare fuses. It is interesting that the Microsquirt manual suggest that the Microsquirt grounds go directly to the engine block. The above diagrams don't show that. It is also suggested that the grounds for the coils also go directly to the engine block. I guess I now know what those two bolt holes on the head are going to be used for.
Hopefully by separating the above functions, there will be less "noise" in the wiring.
Now I just have to bend some metal and run more wiring. Adding the Microsquirt easily doubled the wire count under the hood.
Author:  MadScientistMatt [ Sat Nov 16, 2024 12:07 pm ]
Nice, these fuse boxes are from the same series that I used in the design of DIYAutoTune's drop on harnesses.
Author:  kesteb [ Fri Dec 27, 2024 12:05 pm ]
The Microsquirt has been mounted. It is located on the drivers side kick panel. About the same level as the fuse box. Now I need to make a bracket to hold the fuse boxes. I have a prototype in 16g cardboard right now. Just need to transfer it to sheet steel.
I am going to wire in the 2 step and the map switch functionality.
The two step will be triggered by my line lock button. A 12v system triggering a 5v system. And the tween shall never meet, or I'll have a $350 paper weight. I have decided to use a relay. The line lock grounds the relay, which should switch the 5v line to ground and also activate the line lock solenoid. There will also be a toggle switch in the circuit to allow the 2 step to ground. I may want to use the line lock without the 2 step being activated.
Should a diode be placed between the relay and Microsquirt to prevent back feed? If so, what size? The same question for the map switch circuit.
thanks
Author:  MadScientistMatt [ Fri Dec 27, 2024 1:23 pm ]
The coil is the part of the relay that has flyback issues; the switch doesn't.
Or for faster response, you can use an optoisolator module.
Author:  kesteb [ Sun Mar 16, 2025 10:45 am ]
So what size of wire do you use for power and ground?
Author:  MadScientistMatt [ Sun Mar 16, 2025 3:16 pm ]
The main power wire was pretty thick, but it also had to carry current for some pretty exotic fan and fuel pump setups. The ground was 10 gauge IIRC.
Author:  kesteb [ Wed May 07, 2025 11:19 am ]
So I am laying out wires for the various sensors in the engine compartment. I am using a throttle body from a first gen Fox body 5.0. Years ago this was the hot item, now, not so much and there may be better options. But it is paid for.
I plan to use the IAC on the throttle body. This has a two wire plug so it is PWM controlled. The question is, does the fidle wire go to one of the lugs and a signal ground to the other? The various manuals are unclear on this.
On mounting the IAT sensor. The OEMs mount them in the inlet track, would mounting it on the manifold, directly behind the throttle body be just as good? It would simplify some wiring.
thanks
In fact a lot of the components that I am using is from that same Ford 5.0. The 24lbs injectors are good for about 225hp, the sensor for the 36-1 wheel is Ford, hell the toothed wheel was designed by Ford, but sourced from a third party. I was going to use an EDIS module from a Ford V6, but I was talked out of doing that. And what is not Ford is GM based. I have a set of 29lbs injectors for a supercharged 1994 Buick V6, the CLR, IAT, the 2bar MAP are GM and the coil pack is LS truck based.
I find it interesting in the design of the various components. Some require a 5 volt reference line and others don't. It would seem that you would want consistence in this regard. Also the coil pack takes more wires then the entire engine did in 1965. That's progress and federal regulations at work. But is it really any better...
Author:  MadScientistMatt [ Sat May 10, 2025 6:51 am ]
The IAC gets switched 12V power on one side and the FIDLE wire on the other. I think it's got a diode in it so you will need to wire it up the same way Ford did. And nothing wrong with using the 5.0 throttle body; modern ones aren't that different.
My experience is that IATs in manifolds, despite the "manifold air temp" name, tend to give a false hot reading as the manifold transfers more heat to the sensor than the air. It's better to put it upstream of the throttle body.
Author:  kesteb [ Wed May 14, 2025 3:22 pm ]
Thanks.
Do you know if DIYautotune sells individual wires? It would be nice to get additional footage of the black/white signal ground and the gray VREF wires. Just to be consistent, so when I make "big splices" for those circuits all the wires are the same color.
Author:  MadScientistMatt [ Sat May 17, 2025 8:40 am ]
You'd have to check with them directly; it won't be on the website. We did this sometimes when I worked there.
Page 1 of 2 All times are UTC-08:00
