| Upgrade 1961 Plymouth Valiant front end to 1962 Plymouth Valiant front end https://mail.slantsix.org/forum/viewtopic.php?t=67981 |
| Author: | crickhollow [ Fri Nov 08, 2024 9:17 pm ] |
| Post subject: | Upgrade 1961 Plymouth Valiant front end to 1962 Plymouth Valiant front end |
It is hard to find lower control arm bushes for the 1961 Plymouth Valiant. What is involved in upgrading to a 62' Plymouth Valiant front end? Thanks |
| Author: | Greg Ondayko [ Sat Nov 09, 2024 4:07 am ] |
| Post subject: | Re: Upgrade 1961 Plymouth Valiant front end to 1962 Plymouth Valiant front end |
You need the entire k frame and steering box, engine mounts, and lower control arms. Possibly strut rods, and upper control arms, spindles. Not sure on the steering linkages/ center link/ pitman arms/ idler arms. The swap will work with any slant 6 k frame in a '66-'62 A body. Steering column might need swapped as well. |
| Author: | SlantSixDan [ Sat Nov 09, 2024 2:17 pm ] |
Not sure on the steering linkages/ center link/ pitman arms/ idler arms All different between ['60-'61] and ['62-'66].Quote: Steering column might need swapped as well
Yep.
